Lightning port bent, iPhone not charging.
My iPhone 8 is not charging. I noticed that the outer housing of the lightning port has bent. I have got the lightning port inside replaced , but the phone still doesn’t charge.
Es esta una buena pregunta?
You’ll need to either replace or rework the housing in order to get that working again, I imagine the cable isn’t connecting with the pins inside.
You can just use a wireless charger though…
Fue útil esta respuesta?
I think you can getaway with just replacing the Lightning connector iPhone 8 Lightning Connector Assembly and here's the guide Reemplazo del ensamblaje de conector lightning del iPhone 8. and reshaping the case a bit.
Ultimas 24 horas: 0
Ultimos 7 días: 5
Ultimos 30 días: 16
Todo El Tiempo: 2,370
