Saltar al contenido principal
Lanzado en Septiembre 16, 2016. Modelos 1660, 1778. Disponible en GSM o CDMA / 32, 128, o 256 GB / Oro Rosa, Oro, Plata, Negro Mate y Negro Brillante.
Preguntas 2264 Ver todo
Potential "No Service" Issue iPhone 7
I recently had a buyer return an iPhone 7 due to the device displaying “No Service” all the time. I believed that it was the No Service issue common with the 7 as the model number of the phone matched the model number of the phones affected by the issue.
The phone is still able to recognize a SIM card, displays the IMEI, and Cellular settings are not grayed out whenever a SIM card is in the phone. I tested 2 different SIM cards with the phone. Both times, the device would recognize the card and display the cellular carrier in the corner. After a minute or two, the phone would then display no service.
Is the problem caused by the “No Service” Issue, or is this another problem? Thanks for the help!
Es esta una buena pregunta?
Puntuación 0
Agregar un comentario
1 Respuesta
Solución Elegida
What carrier is the customer using? AT&T and the MNVOs who don’t use others as fallback are known to have coverage issues because of how bad their cellular coverage is known to be in some areas, especially with certain phones where the problem is made worse. Before you rule out the phone as a dud, try to use it on a carrier with good coverage in your area for 1 month and then the matching carrier for 1 month. If it works out, then the phone is fine and the customer has coverage issues. You’re better off waiting until you know it’s good before selling it again since it’s potentially defective.
If it isn’t the network, try and use the Apple repair program and get the phone swapped out - although most of these are probably old enough they’re over 3 years old and won’t qualify. A little unethical maybe, but Apple has had these problems enough it isn’t something I would feel too bad about since they drag it out until they only legally have to fix phones people stood their ground on.
The problem with trying to fix the board is Apple isn’t being open about the chip at fault, so unless you’ve repaired these for someone to use again it isn’t something you may know how to fix. I’m suspecting it’s due to a bad baseband IC (Intel in the inferior AT&T/T-Mobile SKUs or Qualcomm in the factory unlocked/Verizon/Sprint* SKUs) and see if it can be reflowed or reballed. You cannot change it as it is paired to the baseband IC, so you have to reball it. The work required to recycle the old board is not worth it - just change the board if it’s a hardware flaw.
*Sprint phones are locked, unlike Verizon postpaid. They got an ODI exception Verizon did not.
Fue útil esta respuesta?
Puntuación 0
4 comentarios:
Thanks for the reply. I'm going to try to get it repaired through the program through Apple. I did replace the screen on the phone myself. Do you know if Apple would refuse to repair the device because of this?
- de
@hay_den They might try and use it as an excuse. Stay quiet about it and deny everything that seems like an excuse to get out of it.
- de
Will do. Thanks for the help!
- de
@hay_den It's about the only good option you have outside of selling it AS-IS/Parts only that's practical.
If the phone is too old for the program, try the original network and a good one and see if it has no service problems.
- de
Añadir tu respuesta
Hayden Roof estará eternamente agradecido.
Ver Estadísticas:
Ultimas 24 horas: 1
Ultimos 7 días: 1
Ultimos 30 días: 13
Todo El Tiempo: 931
