Saltar al contenido principal
Guías de reparación para computadoras de escritorio Dell.
Preguntas 443 Ver todo
PSU light is flickering green. Otherwise no power Dell Inspiron 3847
Had a power outage the other day.  Once power was back, my Inspiron 3847 would no longer boot. No power at all. No light on power button. PSU had green light, but was dim and flickering / pulsing a bit.
I followed the PSU test from this page: ++https://www.dell.com/support/article/us/...
Steps tried:
  • Opened up the case, and unplugged the PSU from all components. I plug in power, and light is full bright, solid green.
  • When I plug in the 24 pin to the motherboard, it goes back to dim and flickering. (Motherboard was disconnected from everything else at the time)
  • Swapped out the motherboard with another of same type. Light still dim and flickering.
The motherboard I swapped it with was a used one, and supposedly tested and working. So it's possible that one was also bad, but that doesn't seem likely, right?
Does this lead me back to a PSU issue?
Es esta una buena pregunta?
Puntuación 0
Agregar un comentario
1 Respuesta
Solución Elegida
Power surge. I would try another power supply first and see how that goes.
Edit: before trying another one try leaving the power supply unplugged for a couple of hours from the wall then plug it back in and try to turn it on again. Might just need to drain the PSU from a power surge to get it working again.
Fue útil esta respuesta?
Puntuación 0
2 comentarios:
I tried your suggestion (leave unplugged... actually overnight). Issue remains. I'll try replacing PSU. Thanks!
- de
The PSU did end up being the issue. After replacing, all is well.
The dell troubleshooting page was helpful, but came up short. It seems to indicate that I could confirm the PSU was ok by unplugging everything internally and testing the light. Obviously in my case, that was not accurate.
Hope this helps others.
- de
Añadir tu respuesta
Brandon Clyburn estará eternamente agradecido.
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 3
Ultimos 30 días: 12
Todo El Tiempo: 616
