Faint pixel thick vertical lines on Apple Cinema Display 27"
I bought old used a1316 Apple Cinema 27” Display to connect to my 15” MacBookPro (Early 2013) and just use both at home mostly for browsing and movies.
Today I noticed faint pixel thick lines about inch from each other all over the screen. Clearly visible on dark backgrounds when MacOS is in DarkMode, but almost impossible to see if screen is completely black or white.
Screen on macbook is fine. I played with different resolutions, reset PRAM, rebooted machine, tried different thunderbolt connectors…
So far, if I’m far enough from the screen it’s not bothering me much. But just wanted to know is this is something I need to worry about? Can the condition of the screen deteriorate?
I made a photo of the screen, not sure how visible issue will be:
Thanks in advance!
Es esta una buena pregunta?
2 comentarios
Got exactly the same problem on my iMac27 late 2009 (which uses a LG LCD). Would be interested to know what specific parts (capacitors?) need to be replaced... Obviously I don't wanna start replacing all possible caps before finding the right ones..
- de user100299334
Could you please tell me, were you able to solve this issue? I'm currently facing a similar situation and am considering whether it's worth trying to fix it or if it's better to sell the device.
- de Dmitriy imortl
