Saltar al contenido principal
La consola de juegos Xbox de tercera generación de Microsoft, lanzada el 22 de noviembre de 2013.
Preguntas 727 Ver todo
Disc drive doesn’t pull in discs
So my Xbox one console doesn’t smoothly pull in a disc like it’s supposed to. If you slide the disc in with some force it spins up and plays as normal. Ejecting the disc works fine but the console does make noises when there isn’t a disc inserted like it’s trying to eject a non existent disc.
I did buy the console used and by looking in the back vents etc it’s pretty dusty inside, could that be the issue? It’s like it doesn’t detect a disc is in the slot until you’ve basically shoved it in.
any way to clean the optical drive inside or is the only option to replace it.
if I do have to replace it do the OG Xbox one models from 2014 used the same blu ray drive or are there variations like with some fat ps3 models?
apologies for the stream of questions lol
Contesta esta pregunta Yo también tengo este problema
Es esta una buena pregunta?
Puntuación 0
Agregar un comentario
1 Respuesta
Inside a disc drive is a little rubber roller. That roller is a friction still, so you will need to open the case (Youtube how to open) and remove the disc drive.
Once out the drive on has four little screws, two of which are under the ends of a piece of the foam. Be careful not to lose the screws.
Make sure you have cotton swabs and rubbing alcohol(90% preferred)
Once open you will dip the cotton swab in rubbing alcohol and carefully clean the rubber roller.
This will remove dust and grim and the roller will grab disks again.
As for the continuous ejecting that is due to a sensor either dirty or stuck.
Easiest fix is to take a can of compressed air and blow out the disk drive while it is open. If you do this without removing it, it will only push the dust into the case.
If all fails, you can replace it with an after market disk drive of the same size that is Xbox compatible.
Best of luck!
Fue útil esta respuesta?
Puntuación 0
Añadir tu respuesta
sambetsy estará eternamente agradecido.
Ver Estadísticas:
Ultimas 24 horas: 1
Ultimos 7 días: 14
Ultimos 30 días: 48
Todo El Tiempo: 7,365
