How to resolve internet connectivity issues?
phone refuses to connect to the wifi
Es esta una buena pregunta?
Replace the Wifi Diversity Antenna: Reemplazo de la antena de diversidad Wi-Fi del iPhone 6s
Fue útil esta respuesta?
One of the things why your phone won’t connect to the wifi is that the Wifi Router you are connecting to has a limited users allowed to connect. Try to turn off your wifi and turn it on back and then connect your phone.
Another thing is that you might entered an incorrect password. Try double checking it and see if it connects directly.
Long story short, your phone doesn’t have any issues at all, it is either you entered the wrong password, or your Wifi Router/Hub has only limited allowable users that can connect.
Hope this answer helps you a lot. I’ve experienced the same thing as well here in my country :D
Thanks for trying, but I had already thought of that and tested multiple different routers. It is an issue with the phone
@elijahsrook001 how about checking it out if what kind of WIFI Version you have with your phone and what WIFI version your router had... because WIFI 4G and WIFI 5G Versions are not compatible to each other.
versions of the wifi somehow affect the reason why you can't connect :D
If a phone has a 4G connection and the router has a 5G connection, the phone's internet speed will be 4G. If the phone has a 5G connection and the router has a 4G connection, the phone's internet speed will be 4G. Both devices are still compatible and this will have nothing to do with the phone not connecting. I appreciate your feedback, but I have resolved the issue. Thank you.
Ultimas 24 horas: 0
Ultimos 7 días: 0
Ultimos 30 días: 0
Todo El Tiempo: 71
