Saltar al contenido principal
Número de pedido de Apple MC007LL / A / 27" Pantalla de 2560x1440 píxeles
Preguntas 78 Ver todo
hello can I fix vertical line 4 inch going from top to bottom?
I replaced logic board because I thought it caused problem but please look at the pictures
there is 4 inch line going from top to bottom is it LCD or connector cables inside?
Contesta esta pregunta Yo también tengo este problema
Es esta una buena pregunta?
Puntuación 0
4 comentarios:
just replaced T-CONE did not work, still same strap 4 inch going from top to bottom
need help
- de
I am thinking may it be video cable connector?
- de
need help, T-Con board was replaced and same nothing changed
- de
Agregar un comentario
1 Respuesta
This looks like a messed up T-CON board issue which is on the backside of the LDC panel. Here’s the P/N for the full display Apple P/N 661-5542. Here’s one source 661-5542 Apple LCD Display for 27" LED Cinema Display. I haven’t used them let so let us know if you have any issues.
Fue útil esta respuesta?
Puntuación 0
1 comentario:
thank you ! I will buy it and replace
- de
Añadir tu respuesta
Michael Niedzwiadek estará eternamente agradecido.
Ver Estadísticas:
Ultimas 24 horas: 1
Ultimos 7 días: 1
Ultimos 30 días: 2
Todo El Tiempo: 69
