Saltar al contenido principal
Lanzado el 22 de septiembre de 2017. Modelo A1864, A1897. Disponible como GSM o CDMA / 64 o 256 GB / oro, plata y gris espacio.
Preguntas 261 Ver todo
Did damage to the fingerprint reader break iPhone 8+ charging circuit?
My iPhone 8+ screen is cracked. It seems to have been struck at the left edge of the fingerprint reader. I want to fix the phone but am concerned about the reader being damaged as i understand a replaced reader will not read fingerprints again unless it is replaced by Apple. A key symptom is “The phone will not charge”. I plug in a cable but the screen stays blank. SO, what is the likely hood i can reuse the fingerprint reader when replacing the cracked screen?
Contesta esta pregunta Yo también tengo este problema
Es esta una buena pregunta?
Puntuación 0
Agregar un comentario
1 Respuesta
Unless the home button has suffered physical damage from the drop it should still work fine. However to be 100% sure you will need your phone to boot.
 So you don’t really have any alternative but to replace the screen. If it still won’t boot you could check the battery and dock, other than that you will need it looked at by a repair shop.
Fue útil esta respuesta?
Puntuación 0
Añadir tu respuesta
steve brown estará eternamente agradecido.
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 0
Ultimos 30 días: 13
Todo El Tiempo: 13
