Saltar al contenido principal
Repara tus cosas
Derecho a Reparar
Partes y herramientas
Home theater receivers by Marantz.
Preguntas 26 Ver todo
Why does my reciever have static, everytime I turn a knob?
My reciever has static everytime, I turn a knob or push a button.
Contesta esta pregunta Yo también tengo este problema
Es esta una buena pregunta?
Puntuación 0
Comentarios:
Hi,
What is the model number of your receiver?
- Por
Agregar un comentario
Kits para Nintendo Switch
A quick fix to get back in the game
Shop Switch Kits
Shop Switch Kits
1 Respuesta
Respuesta Más Útil
I will assume that the receiver is old enough to have a real volume control as opposed to a “digital” one. That being said, older systems have open controls that can get dirty. Using a switch cleaner spray that contains a lubricant as well should resolve this. In detail: volume controls have a fixed resistance coil between 2 of the three tabs on the unit. The third is connected to a “wiper” that makes contact with that resistance coil (or flat surface) and varies the resistance for the circuit which is seen as a change in the volume. If there is dirt, dust,debris present, the contact may be briefly interrupted which will result in the noise that you hear. Using the spray will not only remove any debris from the unit, it will also provide a protective layer that should prevent the problem from recurring for quite a while. This is a common failure that is easily remedied.
Dan
Fue útil esta respuesta?
Puntuación 1
Añadir tu respuesta
thatbeme74 estará eternamente agradecido.
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 0
Ultimos 30 días: 1
Todo El Tiempo: 16
