Saltar al contenido principal
El Airport Time Capsule es un enrutador inalámbrico y un dispositivo de almacenamiento conectado a red (NAS) fabricado por Apple. El modelo A1409 es la cuarta generación de la Time Capsule, lanzada en junio de 2011.
If I can, how do I replace the HDD with a SSD
If i can, how do I replace the HDD with a SSD in my Time Capsule? After all an SSD would be much faster.
Es esta una buena pregunta?
Puntuación 4
2 comentarios
Also, will the SSD even effect the speed of my backups or will it stay the same? I was hoping that it would make my backups faster
- de
It won't hasten anything as you're bottlenecked by the connection interface from the logic board.
- de
Agregar un comentario
3 Respuestas
Solución Elegida
  1. Physically connect the SSD. Place the SSD in the enclosure or connect it to the USB-to-SATA adapter, and then connect it to your laptop with the USB cable.
  2. Initialize the SSD. ...
  3. Resize the current drive partition to be the same size or smaller than the SSD.
Hope this is helpful!
Regards,
Lewis
Admin
Apps4rent | o365CloudExperts
Fue útil esta respuesta?
Puntuación 1
2 comentarios:
Great thank you!
- de
Great but how do I connect an SSD to the HDD connector. No doubt I need a convertor. But what is available and what do I need pls
- de
Respuesta Más Útil
Replacement HDD larger than 2 TB?
May be this helps. SSD will improve the speeds provided you have SSD on your laptop/desktop so that it can send data QUICK.
also any wireless backup will depend on your wireless router.
Puntuación 1
2 comentarios:
Thanks for the info!
- de
that is not my question. I am looking for advise about the connection.
The SSD needs another and smaller connection than the HDD.
I could not find this connector and therefore I placed the question on the forum. I hope that some person can tell me what I need and where to get.
- de
This generation Time Capsule came with SATA magnetic hard drive. Inexpensive SSDs with SATA connectors are widely available in 2.5 inch format (typically used in laptops). Initialize the SSD drive prior to insrall so that it is recognized. After install, the Time machine app will ask to format the drive.
Puntuación 0
Añadir tu respuesta
Strider estará eternamente agradecido.
Ver Estadísticas:
Ultimas 24 horas: 3
Ultimos 7 días: 12
Ultimos 30 días: 41
Todo El Tiempo: 7,018
