Saltar al contenido principal
Únete a la Comunidad de Reparación - Crear Cuenta
Procesador Intel de doble núcleo modelo A1502 / 2.4, 2.6 o 2.8 GHz / Lanzado en octubre de 2013
Would a 2015 13" MacBook Pro battery be compatible with a late 2013
Would a 2015 13" macbook pro battery be compatible with a late 2013 a1502 13” macbook pro. Thanks
Es esta una buena pregunta?
Puntuación 0
Agregar un comentario
1 Respuesta
Solución Elegida
The A1502’s from 2013-2015 use different model no batteries A1493 and A1582. They are both cross compatible. But if possible try to match the battery model number.
I’ve used vice-versa and it has worked either way.
Fue útil esta respuesta?
Puntuación 5
3 comentarios:
Alright thanks, I've got a 2013 a1502 that arrived with no battery. Is there anyway to figure out which one it had? Thank you
- de
That one used the A1493 battery. Getting the a1582 battery is a better choice as the battery cells will be newer and better than a battery that was made in 2013.
- de
For what it’s worth, I ordered a 1502 battery and ifixit sent me a 1582. The fit took some effort, as the fit wasn’t perfect, but I got it in. And it works!
- de
Añadir tu respuesta
Callum Menzies estará eternamente agradecido.
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 7
Ultimos 30 días: 31
Todo El Tiempo: 765
