Saltar al contenido principal
El iPhone 5s de Apple fue anunciado el 10 de Septiembre, 2013. La reparación de este dispositivo es similar a los modelos anteriores y requiere destornilladores y herramientas de palanca. Disponible como GSM o CDMA /16, 32, o 64 GB / Plata, Oro, y Gris Espacial.
Preguntas 3531 Ver todo
charge ic u2 missing pads
My Iphone has 3 lost pads. ic charge
u2. Is it possible to recover these pillows? What is the solution?
Meu Iphone está com 3 pads perdidos. ci de carga u2. É possivel recuperar essas almofadas? Qual a solução?
Es esta una buena pregunta?
Puntuación 0
Agregar un comentario
2 Respuestas
Solución Elegida
It seems not only the pads are missing but also the surface part of the connecting rails have been teared away. They all go directly to the processor, thus there’s no place to bridge them. Board can be trashed, not recoverable.
Fue útil esta respuesta?
Puntuación 3
1 comentario:
Friend. I followed the path of these pads and they are plugged right into the CPU. The middle ones are easier to jumper. Thanks for your info. I will change the motherboard and in the future I will try to do an experiment. I found boards with all the pieces except the chips. I'll try to transfer nand memory and cpu to such a card
- de
The solution would be to find out where the pads go and run jumpers. It shouldn’t be that difficult as they look like the outside pads.  It only gets time consuming when the middle pads are missing and you have to turtle the chip.
Puntuación 2
1 comentario:
- de
Añadir tu respuesta
PAULO SIQUEIRA estará eternamente agradecido.
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 0
Ultimos 30 días: 0
Todo El Tiempo: 109
