Saltar al contenido principal
Lanzado en noviembre de 2016, el PS4 Pro cuenta con hardware actualizado para juegos de 4K y streaming de vídeo.
Preguntas 384 Ver todo
Snapped disc stuck in drive, wont eject manually.
My son, in temper, snapped a disc panicked and push half the broken disc back in, it wont come out automatically or manually (I’ve tried taking off the top and turning the manual screw) I took it to a repair centre who say that the only way to fix is it to replace the drive but that would be expensive, any ideas at all?
Contesta esta pregunta Yo también tengo este problema
Es esta una buena pregunta?
Puntuación 0
Agregar un comentario
1 Respuesta
unless the snapped disc damaged the drive, the shop is just trying to get you on a replacement.
it is 100% possible to remove the disc drive and take the drive itself apart to remove the disc. I’d find another shop that is more helpful and willing to work with you on it, removing the disc and charging you a labor fee if the drive still works and if it doesn’t then offer you a replacement cost.
you could also try it yourself, but there are dangers involved for an expensive machine like this. I believe there’s an ifixit guide on removing the disc drive however
Fue útil esta respuesta?
Puntuación 0
2 comentarios:
Do you have a link to the guide? Im brand new to this site I found it looking for any help to fix it.
- de
Añadir tu respuesta
Shellie Palmer estará eternamente agradecido.
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 3
Ultimos 30 días: 13
Todo El Tiempo: 711
