Saltar al contenido principal
Guías para la versión Wi-Fi del iPad Mini 2. Anunciado el 22 de octubre y lanzado el 12 de noviembre de 2013. El iPad mini 2, también conocido como iPad mini con pantalla Retina, tiene todos los píxeles del iPad Air en un tamaño más pequeño de 7.9" factor de forma.
Preguntas 220 Ver todo
Part of the screen has no image after repair
The touch screen connector was replaced. After that, my device worked okay for about a month, until this issue appeared:
About one quarter to one third of the screen became gray blank. It is always the same size, but the “texture” changes. When you turn the screen on, this blank part starts black, then it slowly goes gray (brighter) and so the texture becomes clearly visible. Also, there are very rare moments, when this blank part disappears at all and you can see the full screen, as it should be, for a second or less.
What I’ve noticed recently (and I’m not sure it was so from the start) is that exactly this blank part is not responsive to touch either.
What might be the problem? What parts of the device have to be replaced or repaired?
Es esta una buena pregunta?
Puntuación 0
Agregar un comentario
1 Respuesta
Solución Elegida
Screen problems showing after replacing a connector on the board would suggest me to first check the work that was done on the board previously. Having been opened before, I’d speculate it was for fixing a previous problem, was it a bump, a liquid damage ? A known good screen would make things easier and help figuring out if it’s an Lcd or a board issue.
Fue útil esta respuesta?
Puntuación 2
1 comentario:
Well, yes, it started when I dropped it (no liquid). So, the screen was broken. I've tried to replace it myself, but failed. I've damaged contacts on the touch screen socket connecter. What I've learned surfing web is that these contacts are especially weak on that model. So, next, I went to a repair service, and they replaced the socket connecter, soldering a new one (the touch screen connecter, not the display one). No other service was done before or after it. I will try another screen, if possible, in the next few days.
- de
Añadir tu respuesta
Aleksey estará eternamente agradecido.
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 1
Ultimos 30 días: 1
Todo El Tiempo: 34
