Saltar al contenido principal
Guías de reparación y soporte para mouse de computadora inalámbricos y con cable de Logitech.
Preguntas 274 Ver todo
How to take apart my Logitech Mouse #402641
I’m not sure which Logitech mouse I have. I’ve included some pictures and the only number I see is 402641-000.
I’m trying to take it apart and can only find one screw. I have checked under all the pads and there is
only one screw under one pad. There are no other stickers/pads anywhere, not even a battery sticker.
When I take the one screw out, that side comes up some when I pull, but the other side does not. I don’t know if I’m missing a screw somewhere or it is snapped together really good.
Contesta esta pregunta Yo también tengo este problema
Es esta una buena pregunta?
Puntuación 0
2 comentarios
r u sure you checked under all pads / feet
- de
I'm sure. I pulled them all up and there was only one screw under one of them.
- de
Agregar un comentario
3 Respuestas
Respuesta Más Útil
It’s a Logitech MX620 based on the part number. The mouse is held together with screws under the pad; you didn’t look hard enough.
If you need an idea on how to take it apart, refer to this video. It isn’t English, but it goes over mouse disassembly and should be easy to follow along.
Fue útil esta respuesta?
Puntuación 2
This Logictech is not exactly the same but will probably help a lot:
https://www.youtube.com/watch?v=VThb7EGP...
Without a model number you could look for hours.
Puntuación 1
yes unscrew all of the visible screws and it should come off and then do what you have to do and put back together.
Puntuación 0
Añadir tu respuesta
Audrey Hodge estará eternamente agradecido.
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 1
Ultimos 30 días: 10
Todo El Tiempo: 724
