Saltar al contenido principal
Repara tus cosas
Derecho a reparar
Partes y herramientas
Una colección de guías y soporte para reparación de lavadoras
Preguntas 2458 Ver todo
Washing machine stops after filling, but works if I advance the dial
I have a Maytag top loading machine that’s about 10 years old (model #MTW5600TQ2). It sat unused in my mother’s basement for a few years, but I recently decided to moved it into my house and put it to use. After we moved it, I ran the machine and it was clear it wasn’t spinning. (The clothes were too wet when the cycle ended.) So, I called a repair man who said the clutch was bad. I had it replaced (cost about $175). The repairman said it was fixed, but now when I run a load of clothes the machine wants to stop after it fills—like the cycle simply stalls and the knob pops out. If I turn the knob slightly forward (clockwise in the cycle), push the dial in and pull it back out, the cycle will continue as it should—the machine will fill a bit more, agitate, spin and drain. However, it will stop again after it refills for the rinse part of the cycle. Once more, I have to advance the knob slightly, push it in and pull it back out, and it will continue filling, then spin, and finish the cycle. Any ideas about what might be wrong? Given that the machine continues to work (if I manually advance the knob), I don’t think it’s the lid switch. Any suggestions?
Contesta esta pregunta Yo también tengo este problema
Es esta una buena pregunta?
Puntuación 1
Agregar un comentario
Kit de Destornilladores Manta
112 bits for every fix.
Upgrade Your Toolbox
1 Respuesta
The control knob is attached to a clockwork timer. The mechanism is probably worn.
Sometimes you can find a used timer at an appliance repair shop, which I did. Otherwise order on line. They’re easy to replace. Look on u-tube.
Fue útil esta respuesta?
Puntuación 0
Añadir tu respuesta
H Jones estará eternamente agradecido.
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 0
Ultimos 30 días: 0
Todo El Tiempo: 6
