Replaced Tristar, Tristar fails again iPhone 5s
I have an iphone 5s drawing 0.08 amps. I had replaced the 5s tristar with the backwards compatible NXP 610A3B chip that i ordered from the Rossman group. This worked for one charge, then the phone went back to 0.08 amp draw. So i replaced it again with the same result. Ive checked for shorts and most outputs around the PMIC. Where should i focus to get the phone charging and functioning again?
Es esta una buena pregunta?
1 comentario
Did you solved the issue?i think i got the same issue.change multiple tristar but they died after few minutes of charging
- de master Nizar
