Wifi grayed out and will not let me turn on wifi
I have a iphone 6 and the wifi is grayed out in settings and control centre. I really need this fixed. Thanks
Es esta una buena pregunta?
Greyed out Wi-Fi can be caused by two things.
1. No power getting to Wi-Fi chip.
2. Wi-Fi chip is damaged.
I would guarantee your Wi-Fi chip is damaged and will need to be replaced or re-balled. On an IPhone 6 the repair cost would be probably more than your phone is worth.
Fonez.ie do not offer micro soldering. You will need to find a phone repairer who does micro soldering and even then they might not do this type of repair as the Wi-Fi chip has under-fill and it is common to pull pads while removing.
Most phone repairers have quote forms on their website. Send off a few quote forms for replacing the Wi-Fi chip.
Fue útil esta respuesta?
How much do you think it would cost
Probably around $130.00 as it can turn very time consuming if pads lift with the chip.
If your wifi address shows up as N/A you will more than likely have a board level problem than cannot be fixed unless you know what you are doing with board repair. Your best bet would be to bring it in to a repair shop that specializes in microsoldering and board level repair.
If there are no repair shops that specialize near you there are many that accept mailed-in jobs. You could check out https://www.ipadrehab.com/ if you were interested in a mail in repair.
Hope this helps!
Do you think that www.fonez.ie could fix it?
Ultimas 24 horas: 0
Ultimos 7 días: 0
Ultimos 30 días: 0
Todo El Tiempo: 123
2 comentarios
If you go to Settings>General>About does it give you a wifi address?
- de Cody Auch
@codyauch All it says is N/A
- de matthew
