Saltar al contenido principal
Lanzado en Septiembre 16, 2016. Modelos 1660, 1778. Disponible en GSM o CDMA / 32, 128, o 256 GB / Oro Rosa, Oro, Plata, Negro Mate y Negro Brillante.
Preguntas 1361 Ver todo
Screen not sitting flat battery side
I have an Iphone 7 plus that was in need of a screen replacement I have done this job many times for friends and family with god success but this one a real pain. The screen will not stay down on the left side (battery side) the right side is fine with nothing interfering I have read the threads about ribbon spacer being the wrong place. I had an extra brand new screen and this one does the same thing so I believe its something in the phone any ideas?
Contesta esta pregunta Yo también tengo este problema
Es esta una buena pregunta?
Puntuación 0
Agregar un comentario
2 Respuestas
You should check the battery for swelling, it gets old and swells up but it only shows once the screen comes off. It also could swell if the phone has been overcharged, I would definitely check for swelling . Hope this helps
Fue útil esta respuesta?
Puntuación 0
Hi @tromo100
If your battery is in good shape, you may have some frame damage. All you need to do is remove the screen assembly, place the iPhone on a flat surface and look for any gap between the frame and the surface. Use gentle pressure and keep checking until the frame is straight again.
Using a water resistant adhesive kit for this model will also help to keep the screen in place.
Imagen de iPhone 7 Plus Display Assembly Adhesive
Producto
Puntuación 0
Añadir tu respuesta
Tony estará eternamente agradecido.
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 0
Ultimos 30 días: 0
Todo El Tiempo: 34
