Saltar al contenido principal
La TI-84 Plus CE es una calculadora gráfica lanzada en la primavera de 2015 por Texas Instruments. Incluye una pantalla a color de 2,8 pulgadas, puerto USB, aplicaciones, almacenamiento y una batería de 1200 mAh.
Preguntas 82 Ver todo
The place where I insert my charging cord is not working
I’ve had this calculator for a while now, i used it a lot in Algebra 1 but not much in Geometry so I didn’t really pay attention to it that much then. As i was heading to Algebra 2 this year i realized that i would use it. I found the calculator and was ready to charge it. I found it difficult to plug my charger in. Yes, it was exactly the right cord. I double checked with friends that own the same calculator. Please how can i fix this, I definitely can’t afford a new one.
Update (11/03/2019
does anyone know if this would work?
Es esta una buena pregunta?
Puntuación 1
Agregar un comentario
2 Respuestas
Solución Elegida
That’s strange, it looks like your USB port is missing a structural piece that holds the contact points in place. Look at the cable you charge the calculator with, does it have a black piece stuck in it?
Here’s an example of what mine (top) looks like compared to yours (bottom).
Are you familiar with soldering or know someone that can solder? I’ll ask around but I’m pretty sure the only way to fix this is going to require replacing the USB port. You can take a look a the teardown guide so you kind of know what you’re getting into.
Meanwhile, the only way to charge your calculator is to remove the battery and put it in a friend’s calculator, then charge it through their calculator. It should last you a month or so on a full charge if you keep your brightness low (press [2nd] then hold down the down arrow to reduce the brightness).
I would check if your calculator is under warranty still, perhaps TI can replace the calculator for you. If worst comes to worst and you have to buy a new calculator, honestly a TI-83 Plus for $20 on Ebay will get you by Algebra 2. If you have a little extra money I would recommend the TI-84 Plus for about $50-60. Don’t get a TI-84 Plus C Silver Edition! Although it has a color screen, it’s the slowest calculator made by TI and you wont have a good experience with it at all.
Imagen de TI-84 Plus CE Bateria
Guía
Reemplazo de bateria TI-84 CE Texas Instruments
Dificultad:
Fácil
1 - 5 minutes
Guía
TI-84 Plus CE Teardown
Dificultad:
Moderado
40 minutes
Fue útil esta respuesta?
Puntuación 1
2 comentarios:
hi! so i've been downloading games on my ti-84 plus ce. it was working just fine when i think the game crashed or something. it lead me to this page that said error:memory. I can't get out of it or connect it to my computer. What do I do??? Please help anyone.
- de
You should press and hold the reset button for at least 3 seconds. If it doesn't fix it then follow: Técnicas de reparación para TI-84 Plus CE
- de
I really don't know, so I can't form an opinion on Algebra 2. But I hear time and again that even students who took AP Calc in HS struggle in college with math - and a major reason is the college Calculus class is "no calculator" -  so one has to know what function to perform, what the function actually is/does, and do the arithmetic correctly.
@essaytyper
Puntuación 0
1 comentario:
Donald Roberts, how is this related or helpful to fixing their charging issue?
- de
Añadir tu respuesta
tala a estará eternamente agradecido.
Ver Estadísticas:
Ultimas 24 horas: 3
Ultimos 7 días: 18
Ultimos 30 días: 52
Todo El Tiempo: 1,253
