Saltar al contenido principal
Repara tus cosas
Derecho a reparar
Partes y herramientas
Dispositivo disponible en tiendas desde el 22 de septiembre de 2017. Modelos: A1863, A1905. Disponible como GSM o CDMA / 64 o 256 GB / Colores - oro, plata o gris espacial.
Preguntas 358 Ver todo
Why my Battery won't connecter on FPC (iPhone 8 )
Hi, my problem is when I try to plug the iPhone 8 battery into FPC, you can't stand right after the hands are lifted and there was something minus the Ka installer. It cannot be fixed within FPC
Contesta esta pregunta Yo también tengo este problema
Es esta una buena pregunta?
Puntuación 0
Agregar un comentario
Kits de Reparación de Pantalla LCD de iPhone
La opción de presupuesto, cubierta por nuestra garantía de por vida.
Compra kits
Reduce los costos de reparación, no la calidad.
Compra kits
3 Respuestas
Respuesta Más Útil
are you 100% sure the battery is the correct model? that might be what’s wrong. otherwise, check if any of the metal pins on the fpc connector is damaged. make sure to align the cable above the connector perfectly. it may take some time, as it can be really tricky
Fue útil esta respuesta?
Puntuación 1
Comentarios:
Yes The Battery is the correct model
- Por
New battery have sometime that problem or many time battery connect and disconnect process makes battery contact loose to battery connector.
Simply bands the pin on battery flex and cover with small tape and screwed well.
Puntuación 1
Comentarios:
I used my finger to install the battery arrived firmly on FPC and I tried to turn on the device but it didn't work!
- Por
This is becoming a common problem on the IPhone 8. It is the FPC on the board that is causing the problem. Sometimes you can manipulate it to make the battery FPC fit snug but other times you need to replace it.
Puntuación 1
Comentarios:
I unzipped my friend's device to see if there was a difference between his FPC and my FPC I did not find any difference
- Por
Añadir tu respuesta
GPLAYS estará eternamente agradecido.
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 0
Ultimos 30 días: 0
Todo El Tiempo: 38
