Saltar al contenido principal
Repara tus cosas
Derecho a Reparar
Partes y herramientas
La tan esperada actualización de la popular MacBook Air, con procesadores Intel Core i5, una pantalla Retina actualizada y muchos otros cambios y actualizaciones. Lanzado el 7 de noviembre de 2018.
Preguntas 45 Ver todo
Is it possible to recover data from a failed / corroded logic board?
I have a dead MacBook Air (Retina, 13-inch, 2018) with a corroded logic board. I know there are tools out there for recovering data from dead logic boards on the newer MacBook Pros using certain data recovery ports. There don’t seem to be any additional unused ports on this board that would serve that purpose. Is it possible with this model to recover data from a failed logic board?
Contestado! View the answer Yo también tengo este problema
Es esta una buena pregunta?
Puntuación 0
Agregar un comentario
Kits para Nintendo Switch
A quick fix to get back in the game
Shop Switch Kits
Shop Switch Kits
1 Respuesta
Solución Elegida
Sadly, I don’t think there is any way. You’ll need to speak with Apple directly to see if they have a solution.
As far as I know none of the T2 based MacBook systems have anyway to access data stored on the flash chips when the system dies. The T2 encrypts the data so unless you already had turned it off its too late now and you would still need to have the logic board working. The only hope would be to find someone who has the deep skills to patch your logic board back together long enough to pull your data off.
To clarify about the tool you are speaking about, it was for the 2016 & 2017 MacBook Pro models which used a different architecture. The 2018 & 2019 models use the T2 chip.
Fue útil esta respuesta?
Puntuación 5
Añadir tu respuesta
Zachary Lunte estará eternamente agradecido.
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 7
Ultimos 30 días: 18
Todo El Tiempo: 53
