Saltar al contenido principal
iPhone de 4 pulgadas lanzado en marzo de 2016 con especificaciones de hardware similares al 6s. Disponible en Plata, Gris espacial, Oro u Oro rosa con opciones de almacenamiento de 16/64 GB. Modelos A1662 y A1723.
Preguntas 1049 Ver todo
iPhone SE will not charge/is not recognized by PC
Hello.
My iPhone SE was charging and was being recognized by my PC until last night. Now, it will not charge and when I plug it in to my Windows 10 PC, I get a notification saying that the USB device has malfunctioned.
I do not have official charging adapters or Lightning cables, but I have tried two AmazonBasics charging adapters, multiple outlets, and multiple USB ports. The device continues to not charge and to not be recognized by Windows.
I don’t have any data on the device, so I don’t care about losing data. Also, I only have one Lightning cable, so I can’t try to charge the device with another Lightning cable.
I looked through multiple questions on the Answer Forum and responses talking about a U2 connector. Does it seem likely that a faulty U2 connector is my problem or could it be something else?
If it helps, I’ve been keeping my iPhone plugged into USB 3.0 ports on my PC a lot lately and about two days ago, my iPhone got atrociously hot while it was plugged into one of them.
Thanks.
Edit: So it’ll actually charge until its powered on. Once the iPhone is done booting, the charging stops.
Edit 2: I got the device off of Swappa, so I don’t know if it has any history of repairs, but going by the answer to this question, I think that by using the USB port on my ThinkPad, I damaged the charge circuit on the logic board: My iPhone won't charge unless turned off
Es esta una buena pregunta?
Puntuación 0
Agregar un comentario
2 Respuestas
Solución Elegida
Yes, a different behavior in charging when phone is on or off points to a faulty charging circuit and a Tristar replacement is most probably needed (no U2 IC exists on the iPhone SE).
The overheating you experienced is also a hardware fault indication that’s due to a short to ground. I’m quite hesitant to recommend fixing the iPhone given the present SE market value..unless you have a 32GB and up version the repair cost would be close to a second hand phone. It’ll be good for the environment to avoid another device going into landfill but close to neutral to your pockets..ultimate decision is of course yours.
Fue útil esta respuesta?
Puntuación 1
Respuesta Más Útil
Hi @beefstewart
Check for dust or dirt in the charging port. This can keep the cable from making a good connection with the phone. Any history of water damage can also corrode the pins inside, making a good connection impossible. If you suspect either of these issues, it might be worth trying a replacement charging port to fix this problem.
If the charging port doesn’t fix your problem, it will most likely be a problem with the U2 charging IC.
Imagen de iPhone SE (1st Gen) Lightning Connector and Headphone Jack
Producto
$19.99
Puntuación 1
Añadir tu respuesta
Steven estará eternamente agradecido.
Ver Estadísticas:
Ultimas 24 horas: 2
Ultimos 7 días: 2
Ultimos 30 días: 11
Todo El Tiempo: 487
