The green and orange charging light flashes back-and-forth constantly
When I’m charging the calculator the green and orange light flash back-and-forth constantly, The calculator won’t even turn on, what’s my problem?
Es esta una buena pregunta?
First, I’d try charging it from a different power source (like a different power brick or use your laptop). If the problem persists, then that sounds like a bad connection with the battery or something has gone wrong with the battery. When the LED turns orange, that means it’s trying to charge the battery but when it turns green that means it’s not detecting a battery to charge.
Try taking the battery out and inspecting it for any damage and check if the three metal contacts are clean. Refer to Reemplazo de bateria TI-84 CE Texas Instruments if you need help with that. If the battery looks fine, then you might want to try a friend’s known, working battery or buy a new one to try. There’s a slight chance that pressing the reset button on the back of the calculator can force it to come back to life.
Could you please tell me how old your calculator is? Someone recently posted a similar question and I’m wondering if they’re related.
Fue útil esta respuesta?
Ultimas 24 horas: 7
Ultimos 7 días: 36
Ultimos 30 días: 163
Todo El Tiempo: 10,297
My calculator does that too it’s like blinking black and green lights would it be the battery or something else that can be fixed ?
Casio fx-991ES PLUS
- de La Luce
@la luce I'm not all that familiar with Casio but a battery replacement would be the first thing I'd try.
- de TheLastMillennial
