Saltar al contenido principal
Únete a la Comunidad de Reparación - Crear Cuenta
Lanzado el 4 de noviembre de 2017. Modelo A1865, A1901. Disponible como GSM o CDMA / 64 o 256 GB / Silver o Space Gray. (Se pronuncia igual que "iPhone 10.")
iPhone X boot loop issue
I am a technician with the skills and access to microsoldering equipment. I am trying to avoid separating the two board layers if possible because it is a pain to get back together and may not be necessary. The phone is doing a 3 second boot loop. I have tried to turn it on with only essential components plugged and I have frankensteined new hardware in order to rule out hardware issues. It is recognized by iTunes. I attempted every reset possible, and none of them work. When attempting to restore the iPhone through iTunes, the restore stops right after extracting software (likely because of whatever is causing the boot loop). On the board level, are there any pads I can test in order to confirm that I need to split the boards? Does anyone have a clue what might be causing the issue? On my USB detector, the output reads a stagnant 0.47A @ 5.09V
Es esta una buena pregunta?
Puntuación 1
1 comentario
Mine does exactly the same thing on trying to restore
- de
Agregar un comentario
2 Respuestas
Solución Elegida
Check around nand for shorts. But the problem could be the solder joints.
Fue útil esta respuesta?
Puntuación 1
Try a genuine replacement charge port assembly. They can cause reboots when they go faulty.
Puntuación 1
Añadir tu respuesta
Batteries Bulbs estará eternamente agradecido.
Ver Estadísticas:
Ultimas 24 horas: 3
Ultimos 7 días: 24
Ultimos 30 días: 47
Todo El Tiempo: 289
