Saltar al contenido principal
Version más pequeña del iPad Pro original. Publicado el 31 de Marzo de 2016. Cuenta con una pantalla 9.7", procesador A9X y acciones de almacenamiento de 32/128/256 GB. Disponible en plata, gris espacio, oro y oro rosa.
Preguntas 147 Ver todo
emergency my iPad shows that it is charging but it s not
my ipad shows a battery icon when i press home button and the on off button but after 3 secs it shut down
PS :I’ll let it to 0 pourcentage then i remebered to put it in the charger
btw it is not the first time in the first time i fixed it by the hair dryer in the second time it was stuck on the black screen but it was fixed but pressing the home and on off button at the same time but now i don t know nothing works pleassse help me
Es esta una buena pregunta?
Puntuación 0
Agregar un comentario
1 Respuesta
Solución Elegida
It sounds like a dead battery…however before changing the battery, consider this:
  1. Always try another Lightning cable and charger, preferably Apple original or MFi certified units.
  2. The Lightning cable 8-pin connector should be sitting flush with the housing and completely inserted. If it is not, there could be lint/dust/debris inside the port impeding a proper connection. You can clean it out with a toothpick, fine point tweezers or a dental pick. Just be careful not to damage the pins inside the Lightning Port.
  3. Change the battery. The battery is the weakest link in the entire phone and certainly for charger related issues. It is also the easiest thing to replace. Use a battery utility, such as coconutBattery (for Mac) or 3uTools (for Windows) to test the battery prior to removal. Anything less than 70% of design capacity will require replacement.
  4. If the battery is in good condition, you can use a USB Ammeter to determine if the phone is really drawing current when it says it's charging. If it isn't drawing current, then I would change the Lightning/Charge Port.
  5. If a new battery and charge port still don't resolve the issue, then you either have faulty replacement parts (possible) or a logic board issue. There is an IC (commonly referred to as Tristar) responsible for communicating with the charging device and uncertified chargers can damage it. Unplug the battery and connect a known-good (preferably Apple original or MFi) charger to the phone. A properly working phone will show an Apple logo and boot loop. If the Tristar IC is bad then the phone will not do anything.
Fue útil esta respuesta?
Puntuación 2
Añadir tu respuesta
kawloutchu estará eternamente agradecido.
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 0
Ultimos 30 días: 3
Todo El Tiempo: 684
