Will not drain at end of cycle
My Bosh dishwasher has been a problem and will not drain at end of cycle I cleared all lines, not solved then replaced the pump, not solved then replaced the pressure sensor, not solved them replaced the motherboard, not solved detached the long part f the drain hose and redirected the short half to drain into a pail, bravo worked then raised the pail and stopped draining again. Seems that any back pressure causes a E25 and will not drain. Can anyone help?
Es esta una buena pregunta?
3 comentarios
Has it ever worked correctly? Have you changed your disposal lately?
- de mayer
Worked fine for 4 years and we have no garbage disposal. Thanks for looking in.
- de David
Have you checked the float at the bottom of the dishwasher make sure nothing is under it?
- de Jessica
