Saltar al contenido principal
Lanzamiento el 21 de septiembre de 2018. Modelos A1920, A2097, A2098, A2100. Disponible como GSM o CDMA/eSIM o nano-SIM/64, 256, o 512 GB/ Plateado, Dorado o Gris Espacial (Pronunciado "iPhone 10 S.")
Preguntas 375 Ver todo
Swipe up doesn’t work
Hello,
I have an iPhone XS MAX to fix. This phone had water damage and first stuck on the recovery mode.
i was able to bypass the recovery mode by using the third party software but now swipe up doesn’t work so I can’t get to the menu. Do I have to replace the LCD digitizer for this…? Since it is water damaged, I’m sure there are lot of possibilities but I thought that it’s not something to do with the motherboard since the phone can turn on but only swipe up issue.
I tried to go back to the recovery mode and restore the phone but iTunes gave me the code 4005 and the phone got stuck on the recovery mode again so I used the software to bypass and swipe up issue again.
if you have the same experience or know how to fix it, I would appreciate much.
Contesta esta pregunta Yo también tengo este problema
Es esta una buena pregunta?
Puntuación 0
Agregar un comentario
2 Respuestas
Respuesta Más Útil
“Repairing” a water damaged iPhone, especially a dual layer logic board design such as the XS series, is fraught with issues. If this is your own device, thats one thing but if you are fixing this for someone else, you could be in for a world of “warranty” issues. In my experience, unless the liquid damage is very localized in a non-critical area, you are bound to have a one or more latent issues develop over time. Some water damaged phones are easy to recover but others…not so much. Only you have to decide when to cut bait.
At any rate, it sounds like a screen issue as all of the touch related logic is on the screen. The only exception would be some corrosion or damage to the screen connector but you would probably see other issues as well.
Fue útil esta respuesta?
Puntuación 2
1 comentario:
Thank you for your advise. First I could remove the recovery mode and see the home screen with swipe up issue but now it went back to recovery mode again and can’t fix it...yes there might be a lot of potential since this is a water damage but I wanted to try as much as I could to fix this some how. I don’t really see that the connectors of LCD being damaged but maybe good to replace the screen with the new connectors first...?
- de
Hey!
I am here to share my story. I realize many people face it and only a few write a 'report' after they manage to fix it. I check a ton of materials and thought I can provide some valuable input.
So here is my story:
1.     For a week or so, my phone was telling me that there was not enough storage. I ignored it, planning to buy some iCloud later on.
2.     Essentially, one day I woke up and my screen was frozen. It was fully functional, just did not react to touch. The first thing I tried is to reboot it by holding the power and volume and power button. It did not work and triggered an emergency call. The screen was still frozen
3.     The next thing I tried was a hard reboot. You do it by pressing quickly volume up, then volume down, and then pressing and holding power until the Apple logo shows up. It did not help either.  Moreover, now it asked for a password, instead of Face ID, which I couldn’t type.
!!! HERE is where you have to understand, that if a hard reboot did not help you with the frozen screen, there is a 90% chance that the issue is HARDWARE, NOT SOFTWARE.
4.     I did not know that and started to panic a bit. So, I went to do my research. My primary goal at this point was to back up the phone. I still thought resetting it to default would help, but I would lose all the data in this case, so with no backup it was not an option.
5.     Note that with the screen locked, there is NO option I could find to access your data (yes, I tried external software too). Apple really took care of that. I saw people using external OTPs, such as here: https://vm.tiktok.com/ZGJsfRorK/ But I didn’t have experience with it first-hand.
NOTE: if you are stuck in recovery mode (black screen with text) This tool https://www.reiboot.com/ indeed helps you to get out of it.
6.     Next, I found out how to get a phone into recovery mode (same process as hard reboot, but you should connect it to the computer first via wire and hold the power until it boots into recovery mode (it will say that on a phone screen).
7.     Many sources suggest updating the software. It could have helped if the issue was software, as the update "rebuilds" the software by fixing a bug. However, I advise you not to do it, if your storage is full! I tried the update and ended up with a white "swipe to recover" screen. At this point, I thought I ruined it all.
NOTE: in recovery mode DO NOT press RESTORE if you want to keep your data. This would erase your phone, so simply pretend this button does not exist.
8.     Back to my story, I ran out of at-home options so I went to Apple. They were the most incompetent and told me that the data was lost (spoiler it wasn’t). They proposed to change the screen, but that would imply erasing the phone first (due to European GDPR policy) I refused and left frustrated.
9.     Next, I did some more digging and found out that "swipe up to recover" implies that there is something wrong with the software (in my case it did not install properly due to lack of memory) and the phone will try to "rebuild" the system when you swipe. So, if you have this screen, here is what you need to know. If you swipe it, the data won't be lost. If everything will go well, you will end up with your good old iPhone. What can happen though, is an infinite recovery loop. I did not have that, but here is useful info (see links in the post): https://www.reddit.com/r/apple/comments/...
10.  By now I assumed that my data was still there, but I could not access it and wasn't sure if a boot loop would happen or not. So, I went to an unauthorized repair shop to change the screen. We tried two screens, but none of those worked (did you really think it would be that easy? XD)
11.  I was so confused at that point, if it is not the screen's digitizer and not the software what could it be? I did final research (used all my university research skills here for real) and found out that the issue could be the motherboard, I think it is the same as a logic board (not 100% sure)
12.  The thing is it recures a sophisticated set of hands to fix. I took my time to find a small repair shop that explicitly claimed that they can fix the motherboard issue. So, I went to them asap.
13.  They disassembled the phone and fixed the motherboard. And what do you know, the screen worked. Only it wasn't my screen XD. As it turned out both the motherboard and screen's digitizer were malfunctioning. So, we ended up fixing the motherboard and replacing the screen with Apple’s OG screen.
Result: I swiped to recover, and the phone gradually recovered itself. It took several hours, so be patient :) The financial damage was 200 Euros for all the repairs (note, I live in Eastern Europe, and probably would be more in the US)
Conclusions: few takeaways here:
1.     If a hard reboot did not help, there is a high chance it is not a software problem
2.     In my case full memory was completely unrelated, it was just a coincidence
3.     On the hardware side, touch might not work due to screen digitizer OR motherboard issues (both in my case)
4.     Don't update the software if your storage is full, it can lead to a 'swipe to recover" and a boot loop.
5.     Don't try to look for a reason behind it, maybe you dropped the phone a few months ago, water damage, or maybe there was an electricity overflow at some point when you charged the phone, the motherboard is a very sensate thing…
6.     If you are in the EU, Apple will not help you to recover data. Due to GDPR authorized shops can’t work with your phone while your personal data is on it.
7.     Consult a sophisticated technician after you tried a hard reboot
8.     Don’t panic, your data will not erase itself, unless you reset the phone through iTunes/Finder or physically destroy the motherboard storage unit
Epilogue: after all that, the first thing I did is turned on iCloud backup (except photos). In terms of photos, I turned on iCloud photo library and in about 4 days all 30.000 of my photos were backed up there. I also did a local backup on my Mac just for safety, and a backup of my Mac on an external drive. So, yes, I think spending an extra penny on cloud storage is a good investment. And don’t try to fix everything yourself, I spend 2 very stressful weeks trying it, consult the technician, it could really save your day. Don’t panic and good luck! Also, DM on Instagram if needed https://instagram.com/amelin.svg?igshid=...
Puntuación 0
Añadir tu respuesta
Alltech estará eternamente agradecido.
Ver Estadísticas:
Ultimas 24 horas: 1
Ultimos 7 días: 1
Ultimos 30 días: 4
Todo El Tiempo: 255
