Saltar al contenido principal
Kenmore is a popular appliance brand commonly sold by Sears, but Sears does not manufacture any of the appliances themselves. Instead, they source that out and have other manufacturers make their appliances for them. Kenmore refrigerators are made by a variety of different manufacturers including LG, Electrolux, GE, and Whirlpool.
Preguntas 117 Ver todo
Refrigerator repeatedly stops cooling (freezer/lights work)
Our garage refrigerator (Kenmore with the freezer on the bottom) started not cooling in late July. The lights kept working & the freezer kept working, but the top part (the refrigerator section) stopped cooling and the temp adjustment buttons stopped working for the refrigerator section too. We unplugged it for 24 hours & when we plugged it back in, it started working just fine again... until about 2 weeks later when it happened again. This time while it was unplugged, we cleaned & vacuumed under it and behind it really well and when we plugged it back in we made sure it was pulled out a ways from the wall. Again, it fixed the issue and worked fine for maybe another week or so, but then it happened again! So repeated the process and it did the same thing again yesterday!
Contesta esta pregunta Yo también tengo este problema
Es esta una buena pregunta?
Puntuación 0
Agregar un comentario
2 Respuestas
Respuesta Más Útil
Could be the automatic defroster element/circuit has stopped working and ice build up has stopped the fan that sends cool air into your upper section. When you unplugged it, the ice melted, and once plugged back in, the fridge worked again due to the fan being back in operation, until the ice built up enough to once again stop the fan from rotating. This condition will keep occurring until the problem with the defrosting circuitry has been repaired.
Edit: Probably a good idea to post the model number so that the more experienced participants here have an easier time with helping you resolve your problem. :-)
Fue útil esta respuesta?
Puntuación 2
I have a Kenmore Refrigerator with a freezer on the bottom which is working fine. My problem is the fridge temperature is staying at 47 degrees, I try to play around with the control and it doesn't change always stays on 47 degrees, please guide me what to do with my problem
Puntuación 1
Añadir tu respuesta
Ariel Johnson estará eternamente agradecido.
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 1
Ultimos 30 días: 4
Todo El Tiempo: 153
