Saltar al contenido principal
Released on February 2016, The Asus Chromebook C202 is a ruggedized device created with students in mind. It is a small laptop that can handle minor spills and drops.
Preguntas 17 Ver todo
Why is my chromebook not turning on?
After using, I closed cover—next time I opened it, it would not turn on, with or without power cord plugged in, and no (charging indicator) lights come on when it is plugged in. Battery had plenty of charge when I closed it down.
Contesta esta pregunta Yo también tengo este problema
Es esta una buena pregunta?
Puntuación 0
Agregar un comentario
1 Respuesta
It appears from the following that the unit can be booted minus the battery being hooked up. To eliminate the battery as a potential source for the non-booting problem, I suggest you disconnect the battery and try booting the unit again.
Why is the computer not charging or booting? Battery removal works..
For further information and tutorials (including removing the battery) see:
Asus Chromebook C202 Repair
Fue útil esta respuesta?
Puntuación 0
Añadir tu respuesta
K Einspahr estará eternamente agradecido.
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 0
Ultimos 30 días: 3
Todo El Tiempo: 159
