Whirlpool duet steam model WGD9600TAO
My dryer turns on and heats for 1 to 4 minutes then turns off, continues spinning and will attempt but fail to ignite afterwards. I have found out what the oem part numbers for high limit thermostat is but i see there are kits that is for thermostat and thermostat fuse. But i dont know what parts to pick. Can anyone Please direct me to the correct isle?
Es esta una buena pregunta?
Puntuación
0
If the thermal fuse has blown, I doubt the unit would be producing any heat at all when the dryer is initially turned on. More likely it may be the thermal cut-off cutting in due to an increase of out of specified range thermal temperatures rated for your dryer as the dryer heats up, or the thermal cut-off itself malfunctioning or some other malfunctioning component. Youtube seems to have quite a few videos relating to kit installation so maybe watching some of those will give you a clearer picture of what the problem is. Hopefully some other participants will be able to impart greater detailed information than just the basic thoughts I mentioned. :-)
- de prop man
I may have incorrectly asked my question. I need to replace my thermal cut off switch and it is recommended i also replace the high limit thermostat at the same time and if this dosent remedy then i will have to change the machine control board. What i want to know is if there are lower cost replacement parts other than oem and where i can find them. Im not good at wording my searches and ive no clue if the results i have gotten are what i need.
- de Missi shelli
Please check the model number you gave, it does not pull up a machine.
- de mayer
