Saltar al contenido principal
Quinta generacion de iPhone. La reparación de este dispositivo es fácil y requiere destornilladores, herramientas de hacer palanca, y paciencia. GSM/CDMA /16, 32, o 64 GB / Negro o Blanco.
Preguntas 2191 Ver todo
Why is my phone hot and very short battery life
my I phone 4S gets hot and Battery life is short
Contesta esta pregunta Yo también tengo este problema
Es esta una buena pregunta?
Puntuación 0
1 comentario:
Might be an idea to open up the unit and do a visual inspection of the battery. You could try replacing it with a new battery to see if that clears up the thermal problem. If it doesn't, the increase in heat you have observed could be a sign of component failure or malfunctioning. Might also want to do a search through https://old.reddit.com/r/mobilerepair/ for symptoms similar to your own. I have also seen an app recommended here called coconutbattery which may help in determining the battery's condition.
- de
Agregar un comentario
1 Respuesta
It could be a bad battery. Does it get hot when it is charging only,or even when discharging?
Sometimes a small short can happen. This causes more electricity to flow from the battery and be wasted in heat. A short is when 2 electrical points touch that should not be touching.
You can try to replace the battery. It is quite old now.
It can be a software glitch as well. It’s really trial and error at this point.
Fue útil esta respuesta?
Puntuación 0
Añadir tu respuesta
Bill Marcotte estará eternamente agradecido.
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 0
Ultimos 30 días: 1
Todo El Tiempo: 26
