Saltar al contenido principal
Repara tus cosas
Derecho a reparar
Tienda
Lanzado el 25 de septiembre de 2015. Modelo A1688 / A1633 . La reparación de este dispositivo es similar a las generaciones anteriores, que requieren destornilladores y herramientas de palanca. Disponible como GSM o CDMA / 16 , 64 , o 128 GB / plata, oro, gris espacio, o la opcion de oro rosa.
Preguntas 2418 Ver todo
Troubleshooting dead iPhone after fall
Friend of mine dropped his Iphone 6s, landed hard and busted the screen, we couldn’t get it to turn on with the original so I installed an original 6s screen I use as a testing screen, didn’t work, phone won’t turn on, tried a tester battery also and no joy, any ideas? Suggestions on any further troubleshooting? Everything inside the case is sturdy and fixed in place, no bends nor dents, connectors for the screen look good and no bent pins.
EDIT: tried both regular reset and hard reset, none work.
Any ideas fellow fixers?
cheers
Contestado! View the answer Yo también tengo este problema
Es esta una buena pregunta?
Puntuación 0
Agregar un comentario
2 Respuestas
Solución Elegida
Thanks for the answers guys, after taking it to a friend’s repair shop we diagnosed a busted “charge IC” (don’t know how to say that in english) on the MoBo.
Fue útil esta respuesta?
Puntuación 0
Hi Daniel,
Am i correct to assume, that the phone doesn’t do anything, when you try to power it on? In that case it is time to break out the multimeter and start checking voltages. I’m no expert in these matters. I would advice you check out a couple if videos made by jessa jones of ipad rehab. She makes really informative videos on Iphone board repair.
Best of Luck!
Kingofkeks
Puntuación 0
Añadir tu respuesta
Daniel Guerriero estará eternamente agradecido.
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 1
Ultimos 30 días: 3
Todo El Tiempo: 62
