Saltar al contenido principal
La soldadura es un método para conectar dos piezas de metal entre sí mediante la fusión de otro metal de relleno entre ellas. Existen muchos tipos de soldadura, pero este artículo está diseñado para enseñarle los conceptos básicos de la soldadura eléctrica.
Preguntas 52 Ver todo
Is this recoverable? (Broken Pads)
After laughing with my stupid mistake.. Can this nand be fixed?
This is an iPhone 7 128GB NAND Flash (phone was locked). I accidentally broke the pads while removing it. I also tried scratching the pads a bit, thinking that i could solder there (might have made things worse). However, testing with my multimeter for continuity.. every scratched pad, is now connected to each other.
The reason why i removed the nand is because i bought a U stick, and i was hoping of making a usb out of it
Es esta una buena pregunta?
Puntuación 0
Agregar un comentario
1 Respuesta
Solución Elegida
Depends on how much time you want to invest in this.
If you’re not trying to recover the data from the NAND, I would personally not pursue it, at least for commercial reasons. If it’s a personal project, then have at it and continue to learn.
Fue útil esta respuesta?
Puntuación 1
1 comentario:
its for a personal project.. do you think that soldering on the scratched pads will burn it?
- de
Añadir tu respuesta
Yannis estará eternamente agradecido.
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 0
Ultimos 30 días: 1
Todo El Tiempo: 82
