Why does water pour down when changing filters?
When I remove the old water filter inside my GE model GSS23WSTASS, water pours out until I can get the new filter installed.
Es esta una buena pregunta?
The only reason that I could come up with is that when someone installed the water line to the fridge I'd say that they didn't install a shut off valve on the line before the filter. So I'd suggest before u change the filter again turn the main water line to the house and turn off the water and put in a shut off valve anywhere on the line before the filter. I hope this works for you,good luck.
Fue útil esta respuesta?
Thanks for the quick reply. That makes sense as a plumber, not an appliance repair person, put in a new supply line. The old line had a pinpoint leak and caused a lot of floor damage before we located it.
Ultimas 24 horas: 1
Ultimos 7 días: 12
Ultimos 30 días: 51
Todo El Tiempo: 816
