Water Damage, MacBook won't charge (PPP007)
Spilled about half a cup of cold water over my macbook while it was charging, with most damage done to the charging port. I removed the power adapter, dumped it upside down immediately, shut down and let it rest for about 8 hours.
After that, the Macbook is able to run smoothly, no display problems, all keyboards, USB + earpiece plug work except the charging port. I’ve only noticed it when I went to plug the power in to charge but it won't detect that it is plugged in. I’ve also checked and there’s no issue with the power adapter. Diagnostic test only gave a REF PPP007. As of now, the Mac has ran out of battery.
I have yet to open the Mac but as of now I suspect the IO board is damaged. Can replacing the IO board fix the issue?
Es esta una buena pregunta?
1 comentario
Electronics Water Damage
- de prop man
