Right corner doesn't go in alle the way?
Right corner doesn't go in alle the way, the left one does. How can i Fix this?'''
Es esta una buena pregunta?
As glass is obviously present your best bet is to use one of the guides to remove and reinsert the screen, which I believe is the first part to remove. If you’re not concerned how it looks then just ignore it the 6 or even 6s doesn’t have any water resistance anyway. If I were to guess the cause then it’s likely due to the bendgate issue those particularly with the plus varient suffered from at launch.
Fue útil esta respuesta?
Ultimas 24 horas: 0
Ultimos 7 días: 0
Ultimos 30 días: 0
Todo El Tiempo: 26
