Why does my engin cut out at just under 80 degrees
My ‘82, w123, 200 Manuel transpmission, cuts out at just under 80 degrees. When I start her up again I have to really rev it up to 3000rpm to stop it from repeating itself. I've just recently bought it so I'm not too clued up on what's going on, I feel I should mention that the interior cooling fan isnt working, and no it's not the fuse. I can only drive 5 kms before I have to stop and let it cool down for 20 mins.
I've tested the thermostat and it works correctly. What could it be?
Es esta una buena pregunta?
3 comentarios
Improper cooling? The fan is designed to move air throughout, so maybe its heating up very fast. Check coolant as well. Maybe also see if the radiator is clogged/blocked.
- de Rosa Avrigari
Thank you Jessica
The fan runs at all times and I have checked the radiator, there aren't any blockages... but thank you.. I didn't mention that it has a carb and not fuel injected. Do you think that it could be a fuel issue or would you sway more to the cooling side?
- de Tharwat Londt
Could be fuel issue as well, since you have to push the engine up to 3000rpm to keep it from cutting out. Check the fuel pump, and maybe also follow what cgulyash answered and try and collect data. Check the fuel, electrical, and (maybe) drivetrain systems, to see if anything looks odd.
Also, kind of cool for you to be keeping an old car on the road!
Good luck!
- de Rosa Avrigari
