Saltar al contenido principal
El Acer Aspire Switch 10 SW5-011-18R3 es una tableta 2 en 1 con teclado acoplable que ejecuta el sistema operativo Windows. Fue lanzado originalmente en mayo de 2014.
Device won't turn on
My Acer Aspire 10 won’t power on, though I have an LED power light. I opened up the inside and reattached almost every cable, and it still won’t power on. I have went through almost every tutorial and still cant’t find an answer.
Contesta esta pregunta Yo también tengo este problema
Es esta una buena pregunta?
Puntuación 2
1 comentario:
Try reconnect battery connector (it help me, after that I can power on )
- de
Agregar un comentario
2 Respuestas
Solution:
Please follow steps in iFixit guide - I hope, It will be solved easily.
Fue útil esta respuesta?
Puntuación 0
2 comentarios:
@lucasjak Where is the ram slot?
- de
I'm sorry, the first answer was my mistake, I forgot, that this is not a laptop, but 2 in 1 device. Please, check out a new answer, I hope, it will be helpful.
- de
If you haven’t done anything before you notice the problem then it must be related to the ram, you need to remove it, blast air in the slot, clean the ram with paper and put it back.
Puntuación 0
1 comentario:
I cannot find the ram slot on this computer. I am pretty sure it has internal ram, and it cannot be removed / replaced.
- de
Añadir tu respuesta
Max Uchenik estará eternamente agradecido.
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 1
Ultimos 30 días: 12
Todo El Tiempo: 607
