Short on PP1V1 and PP2V8 not turning on
Hello, I have a water damaged iPhone XS max, it was ultrasonically cleaned but a short was found on PP1V1 and PP1V8, I removed most of the capacitors on that line but the short is still there, could it be a possible CPU short problem ?
What should I try next?
Es esta una buena pregunta?
7 comentarios
Need more info. What are the readings you are getting on these lines? Is the short on the top half of the board or the bottom half?
- de Chris Stables
upper layer, where the cpu is situated
- de Francesco
Have you removed the two audio ic”s U4902 and U5002 yet? They would be the first things I would remove.
- de Chris Stables
no, will try, thx so much, which one of those 2 lines is connected to the audio ic?
- de Francesco
@imicrosoldering hello, IC U4700 was found to be shorted, could removing that fix also the short on PP1V1?
- de Francesco
Mostrar 2 comentarios más
