Saltar al contenido principal
Únete a la Comunidad de Reparación - Crear Cuenta
Smartphone release by Sony-- also known as Sony Xperia Z1 Honami, Sony Xperia Z1 C6902/L39h, Sony Xperia Z1 C6903, Sony Xperia Z1 C6906, Sony Xperia Z1 C6943. Released in September 2013.
The device doesn't turn on and draws little electricity
First it began to bootloop i think and then i couldn’t turn it on at all, then i decided to flash new firmware(5.1.1 stock) i did that right i have done it many times, i supposed it was a hard brick. Then it turned on started to optimize the apps then again it shut down.
And now i can’t enter either fastboot or flashmode. When i plug it in to charge there’s only red light. I tested it and the amperage goes from 0.03A to 0.19A even if i unplug the battery.
So i assume it’s some IC chip failure.
Es esta una buena pregunta?
Puntuación 0
Agregar un comentario
1 Respuesta
Solución Elegida
I fixed the problem by replacing the battery!
Fue útil esta respuesta?
Puntuación 0
Añadir tu respuesta
Angewolf estará eternamente agradecido.
Ver Estadísticas:
Ultimas 24 horas: 4
Ultimos 7 días: 19
Ultimos 30 días: 40
Todo El Tiempo: 171
