Saltar al contenido principal
Repara tus cosas
Derecho a reparar
Partes y herramientas
Basic wireless mouse. Released: 2016
Preguntas 5 Ver todo
Left clicker on my logitech m170 is not responding to clicks anymore
How can i fix the left button that seems to not work, do i have to rewire something? I dont have any clue of what to do, everything seems to be in place
Contesta esta pregunta Yo también tengo este problema
Es esta una buena pregunta?
Puntuación 0
Agregar un comentario
Kits de Reparación de Pantalla LCD de iPhone
La opción de presupuesto, cubierta por nuestra garantía de por vida.
Compra kits
Reduce los costos de reparación, no la calidad.
Compra kits
1 Respuesta
Respuesta Más Útil
Hi @adelsondamar
If you press harder, does it works?
one thing you can try is to open up and check on the buttons and microswitches.
check for any dry solder joints or worn out micro switches on it.
those micro switches sadly now has a limited lifespan..
You can use the multimeter in beep community (digital) or resistance (analog) to test the microswitch.
depress the switch and it should beep, or the analog pointer will move.
I would suggest you to replace the micro switch, which you can order it from ebay / aliexpress, etc.
To replace the micro switches, you need to have some soldering skills, perhaps I say it is not so difficult, else you can ask you friend for help.
Fue útil esta respuesta?
Puntuación 1
Añadir tu respuesta
ADELSON estará eternamente agradecido.
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 4
Ultimos 30 días: 13
Todo El Tiempo: 139
