Saltar al contenido principal
Repara tus cosas
Derecho a Reparar
Partes y herramientas
Revamped version of the iPhone 3G with faster processing speeds. Repair of this device is similar to the 3G, and requires simple screwdrivers and prying tools. Model A1303 / 16 or 32 GB capacity / black or white plastic back.
Preguntas 1966 Ver todo
Pregunta Cerrada
Replaced iPhone 3GS digital display but still have white screen
I dropped my Iphone 3GS on the floor and the display shows a white screen. Nothing appeared wrong with the display, no cracks, etc. I replaced with a new Iphone 3GS display assembly but still shows a white screen. Is the logic board the problem?
Contesta esta pregunta Yo también tengo este problema
Es esta una buena pregunta?
Puntuación 0
Comentarios:
Try a Reset, hold both Home and Power buttons until iPhone restarts on its own.
- Por
Agregar un comentario
Kits para Nintendo Switch
A quick fix to get back in the game
Shop Switch Kits
Shop Switch Kits
2 Respuestas
Pull it apart again and make sure all connectors are tight and all the way clicked in. More often then not, they get loose when you put it back together.
Fue útil esta respuesta?
Puntuación 0
This is usually a sign of a bad lcd (the screen under the glass). If you do replace it, be very gentle with the front of the screen as the liquid contained inside will hold finger pressure and it will be noticeable when re-assembled
Puntuación 0
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 0
Ultimos 30 días: 0
Todo El Tiempo: 872
