My pressure washer valve keeps popping out.
The indicated valve keeps popping out when I turn on the water. I assume it is a safety valve . There is a clamp ring around the outer edge of the part. I’ve changed the rubber gasket on the part but it will not stay in.
Update (06/29/2019)
It's a Simoniz 1700
Es esta una buena pregunta?
Puntuación
0
Does it work? What happens when you press it in?
- de mayer
As soon as the water is turned on, it gets pushed back out. I thought there might be a blockage so I blasted out all the lines with compressed air; still keeps popping out.
- de progmetaldrums
But does the machine work?
- de mayer
Yes, it works.
- de progmetaldrums
Hi,
I'm wondering if it is a faulty pressure relief valve.
Looking through all the 1700 PSI series models parts for a replacement valve for the machine gave no results. You may have better luck.
Perhaps you could contact Simonez and ask them if there is a replacement valve available for your model or what the likely cause of the problem is..
- de jayeff
