play for some second, then write fan-ng and then stop.
When I plugs my Samsung ,it will play for some second, then write fan-ng and then stop. want can cause it
Es esta una buena pregunta?
Hi @ afriday96,
What is the model number of your Samsung DVD player?
fan-ng most probably means "fan no good",
First check that the fan’s air vent is not blocked or obstructed by dust.
If it is clear check that the fan is working (assuming your player has a fan-you don't state the model number).
If it isn't working, check with an Ohmmeter that the fan motor is OK. Do this with the power disconnected from the unit and the fan disconnected from the motherboard.
If the fan motor is OK then you’ll have to check if there is power being applied to the fan motor when the unit is powered on.
Fue útil esta respuesta?
Thank you so much is working now
Thank you so much 😘😘❤️❤️. Is working now
I am having the same problem. I have blown dust away. But still not working. I can't take the lid off my samsung blu ray. Took 2 screws out of back, but still firmly shut
What is the model number of the BluRay player?
@jayeff is Samsung series 5 (HT-D5550W)
I realize that and answered you 2 days ago.
Click on "4 more comments" in the Chosen Solution above to see my comment
Ultimas 24 horas: 1
Ultimos 7 días: 25
Ultimos 30 días: 109
Todo El Tiempo: 9,987
2 comentarios
My fan blows normal but still getting the message
- de Dean Raubach
@Dean Raubach
What is the model number of the player?
A lot of fans have a sensor in them that lets the control board know that they're operating.
If you check the fan connector if it has more than two wires it will have a sensor (usually a hall effect sensor which indicates speed but it could also be another type).
Perhaps the sensor is faulty or the wiring back to the control board
- de jayeff
