Saltar al contenido principal
Modelo A1224 / principios de 2009 / 2.66 GHz Procesador Core 2 Duo
Preguntas 104 Ver todo
Why won’t my iMac fully boot?
My iMac will come on with the Apple logo a spinning wheel and a loading bar. The bar takes around 30 minutes to fill and once it finally finishes the wheel keeps spinning for a couple seconds and then the whole thing shuts down and I have to start again. What do I do? Also when I was trying to work on it I accidentally screwed up something and now the lcd has a red/pink color. Any idea what that could be?
edit: Apple told me the first problem is a hardware problem but I’m not sure what the problem is because I haven’t been able to run diagnostic and I can’t install Mac OS on a new hdd. I think the cd drive might be bad not sure tho.
Contesta esta pregunta Yo también tengo este problema
Es esta una buena pregunta?
Puntuación 0
4 comentarios:
Are you able to get into Safe Mode? Press and hold the Shift (⇧) key when you reboot.
Reference: Mac startup key combinations
- de
When I hold shift it does the same thing as before.
- de
@mrcrazy - Lets try this try booting up in Target Disk Mode holding the T key. Does that work? You should see a FireWire Icon on the screen.
- de
Same issue with me !!
- de
Agregar un comentario
1 Respuesta
It does sound like your drive is failing but the display having a red/pink color worries me as that would be a failing GPU and in this series the NVIDIA GeForce 9400M GPU is soldered to the logic board.
Fue útil esta respuesta?
Puntuación 0
4 comentarios:
Backlight failure is usually hinted at by a pink hue, but a loose connection to the display can also cause it.
- de
I don’t think it’s cables because I’ve reconnected them multiple times. Is there anyway I can test if it’s backlight without buying a new one?
- de
Hook up an external monitor to test the GPU
- de
Ok I’ll try that not sure o have anything but hdmi tho
- de
Añadir tu respuesta
Isaac estará eternamente agradecido.
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 0
Ultimos 30 días: 2
Todo El Tiempo: 121
