Why is iPhone 6 plus overheating after housing replacement?
Hello, i replaced housing to my iphone 6 plus becouse it was very damaged, after moving all the components to new housing and turning it on it gets very hot and then turns off, i investigated little bit and seems that that component between screen connectors and simtray.
Es esta una buena pregunta?
1 comentario
When does the iPhone get hot? Also did you put the right screws in the right holes? Because long screw damage can do some weird stuff. Is all the flex cables properly seated in the connectors?
Good luck,
From Ronan
- de Ronan
