Saltar al contenido principal
Released in 1999, successor to the original PowerMac G3, 300-450 MHz, 64 or 128 MB of RAM, 6 or 12 GB HDD
Preguntas 18 Ver todo
won't power on
Hello!
I am also having the same problem. I did what u suggested and nothing. I opened the computer and I noticed that 1 of the plugs P5 was not connected to anything. My question is should that part be connected and if so where? Maybe that is what is causing my G3 not to power up?
Thank you.
Edie
Contestado! View the answer Yo también tengo este problema
Es esta una buena pregunta?
Calificación 0
Comentarios:
Please start a new question as this one has been answered and almost no one will now look at it. Thanks
por
Agregar un comentario
Kits de Reparación de Batería de MacBook Air
A partir de $69.99
Buy Now
A partir de $69.99
Buy Now
1 Respuesta
Solución Elegida
The Plug "P5" is just another 4-Pin Molex power connector. It is used to power a secondary hard drive, and doesn't need to be connected to anything for the computer to work. If the computer isn't powering on, a bad power supply may be to blame. The PowerMac G3 Blue and White (as opposed to newer/older powermacs) uses a standard PC "ATX" power supply. You can buy these at just about any store that sells PC parts, or use an existing one if you happen to have one handy.
Fue útil esta respuesta?
Calificación 2
Añadir tu respuesta
edith estará eternamente agradecido.
Ver Estadísticas:
Ultimas 24 Horas: 0
Últimos 7 Días: 0
Últimos 30 Días: 4
Todo El Tiempo: 832
