Compaq Elite 8300 all-in-one
I have four of these computers that will not complete POST. They produce an error code of a solid red power LED and five beeps. This actual error code does not exist in the HP Maintenance and Service Guide under heading “Diagnostic front panel LEDs and audible codes”. Power Supply tested good (fans run); replaced SODIMM with known working module; replaced CPU with known working CPU.
Es esta una buena pregunta?
3 comentarios
Hi @hammer2nail
check if there are any discrete graphic card installed on the mainboard.
If there are, try removing first and observe if it boots up.
- de Augustine
Hi @hammer2nail ,
Do the beeps change if you try to start the computer(s) without any RAM at all?
Also just because the fans run doesn't mean that the PSU is OK.
Have you tried the paper clip test and use a Voltmeter to test that all the voltages(+12V, -12V, 5V & 3.3V) from the PSU are being supplied and are of the correct value?
- de jayeff
Augustine,
Thank you for your suggestion, There is not an optional "discrete" graphics card installed in this computer.
- de Bill Fungo
