Saltar al contenido principal
An audio/video receiver (AVR or home audio receiver) is a consumer electronics component used in home theaters that convert signals into sound.
Preguntas 251 Ver todo
Technics SA-5550 anti-shock timing circuit
1976 Technics SA-5550 stereo receiver was working perfectly. But then I used air blaster on it to clear out dust, and the the “anti-shock timing circuit” stopped functioning. The literature on this describes the anti-shock timing circuit as “helps eliminate annoying thumps in the speaker after turn-on by delaying turn-on of the speaker terminals”. What is the remedy? Is it possible dust got lodged in the circuit?
Es esta una buena pregunta?
Puntuación 1
3 comentarios
Sounds odd. Are you sure you didn't bump or drop something inside?
- de
I'm quite sure I didn't bump or drop something inside. I only used the dust blaster.
I should add that when powered on, the lighting and the radio signal strength meter are still working.
- de
DO u still have the receiver I am looking for one thx crickern @ gmail com
- de
Agregar un comentario
1 Respuesta
Solución Elegida
mchlgrblsk  ''this “anti-shock timing circuit” would most likely be accomplished by either some capacitors, transistors or relays. TR703-TR707 are listed as protection transistor You’ll have to take a look at your boards for any damaged looking components. There should be SUP8450 board in your amp. That is the one for the power source and speaker protection. It could be dust that shortened things out. Of course also possible that the “air blaster” did move some things around. It might help if you post some pictures with your question. May be someone can see more.
Fue útil esta respuesta?
Puntuación 1
2 comentarios:
I uploaded photos. Nothing is obvious to my untrained eye. I ordered the manual dust blower from this site, to see if I can dislodge anything.
- de
- de
Añadir tu respuesta
mchlgrblsk estará eternamente agradecido.
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 0
Ultimos 30 días: 11
Todo El Tiempo: 483
